[postgis-tickets] [PostGIS] #3244: ST_3DClosestPoint returns garbage in Z for 3dz-2d arg
trac at osgeo.org
Thu Aug 20 13:57:41 PDT 2015
Reporter: strk | Owner: nicklas
Type: defect | Status: new
Priority: high | Milestone: PostGIS 2.2.0
Component: postgis | Version: trunk
Resolution: | Keywords:
Comment (by nicklas):
New fix at r13964 using max and min z-value from 3D geometry to calculate
vertical line.
Also added 2 regression tests catching the tickets example.
strk, close if the fix is ok
Ticket URL: <http://trac.osgeo.org/postgis/ticket/3244#comment:10>
