[postgis-tickets] [PostGIS] #3253: ST_3DMaxDistance curved geometries mixed dimension yields DIST_MAX mode not supported
PostGIS trac at osgeo.org
Fri Aug 21 14:51:10 PDT 2015
supported
  Reporter:  robe     |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  low      |  Milestone:  PostGIS 2.2.0
 Component:  postgis  |    Version:  trunk
Resolution:           |   Keywords:
Comment (by robe):
 nicklas see #3256, I suspect something you changed in r13970 is causing
 this new crash I am seeing.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3253#comment:5>
