[postgis-tickets] [PostGIS] #1384: Issue with geocoding addresses where place name doesn't match
PostGIS trac at osgeo.org
Sun Aug 23 21:03:19 PDT 2015
  Reporter:  robe            |      Owner:  robe
      Type:  defect          |     Status:  closed
  Priority:  medium          |  Milestone:  PostGIS 2.2.0
 Component:  tiger geocoder  |    Version:  trunk
Resolution:  fixed           |   Keywords:
Changes (by robe):
 * status:  new => closed
 * resolution:   => fixed
 * milestone:  PostGIS Future => PostGIS 2.2.0
Comment:
 Okay this actually geocodes fine even though the place name doesn't match
 and the zip code is longer than 5 (presumably it should have a -).  I
 checked google and it thinks that astoria should be 26-01.  That's a
 separate issue that we don't deal with hyphenated street numbers.
 So with tiger 2015 data (i have MA,MN,NY,PA,KS,RI loaded on my windows 7
 64-bit 9.4 desktop) I get:
 test_tiger=# select pprint_addy(addy), ST_AsText(geomout), rating FROM
 geocode('2601 24TH AVE,  NY 111022337',2);
           pprint_addy           |                 st_astext
 | rating
  0 24th Ave, New York, NY 11102 | POINT(-73.9211006425579
 40.7761925056417) |     18
 (1 row)
 Time: 22.624 ms
 geocode('2601 24TH AVE, ASTORIA, NY 111022337',2);
 | rating
  24th Ave, New York, NY 11214 | POINT(-73.9883851176818 40.6000773220411)
 |     18
  24th Ave, New York, NY 11204 | POINT(-73.9743513111828 40.6135516510796)
 |     21
 (2 rows)
 Time: 8311.949 ms
 FROM geocode('26-01 24TH AVE, ASTORIA, NY 11102',2);
 | rating
 40.7761925056417) |     17
 (1 row)
 Time: 17.237 ms
 So second takes much longer to process but still gives more or less right
 answer (given we can't handle hyphenated street numbers).
 For compare
 Google can't handle the first version of the address and gives nothing
 the second it corrects and says
 -73.918206, 40.7744398
 and that the address is: 26-01 24th Ave
 Queens, NY 11102
 So tiger geocoder is in right ball park if only we could do the right
 thing with the numbers.  The last answer (where we feed in the correct
 representation of the address is pretty close to what google returns).
Ticket URL: <https://trac.osgeo.org/postgis/ticket/1384#comment:5>
