[postgis-tickets] [PostGIS] #3259: pagc_normalize_address (standardize_address), doesn't convert numbered street name right
PostGIS trac at osgeo.org
Sun Aug 23 21:47:22 PDT 2015
street name right
 Reporter:  robe                 |      Owner:  robe
     Type:  defect               |     Status:  new
 Priority:  medium               |  Milestone:  PostGIS 2.3.0
Component:  pagc_address_parser  |    Version:  trunk
 Keywords:                       |
 This isn't so much wrong as, just not pretty 9nd Leo needs it pretty since
 he uses it to standardize the look of his addresses) and with the TIGER
 data the way it is, ends up geocoding wrong and often being confused for
 highway  and route numbers.
 Here is an example I have in regress, where I prefer the default
 normalize_address behavior over the address standardizer one.
 -- good
 test_tiger=# SELECT  address, streetname, streettypeabbrev FROM
 normalize_address('212 3rd Ave N Suite 560, Minneapolis, MN 55401');
  address | streetname | streettypeabbrev
      212 | 3rd        | Ave
 (1 row)
 --bad
 pagc_normalize_address('212 3rd Ave N Suite 560, Minneapolis, MN 55401');
      212 | 3          | AVE
 (1 row)
 -- bad
 test_tiger=# SELECT *
 test_tiger-# FROM standardize_address('pagc_lex'
 test_tiger(#        , 'pagc_gaz'
 test_tiger(#        , 'pagc_rules'
 test_tiger(# ,'212 3rd Ave N Suite 560, Minneapolis, MN 55401'  ) ;
  building | house_num | predir | qual | pretype | name | suftype | sufdir
 | ruralroute | extra |    city     | state | country | postcode | box |
 unit
           | 212       |        |      |         | 3    | AVE     | N
 |            |       | MINNEAPOLIS | MN    | USA     | 55401    |     |
 SUITE 560
 (1 row)
 --bad
 CREATE EXTENSION address_standardizer_data_us;
 SELECT *
 FROM standardize_address('us_lex'
         , 'us_gaz'
         , 'us_rules'
 |   unit
           | 212       |        |      |         | 3    | AVENUE  | NORTH
 |            |       | MINNEAPOLIS | MINNESOTA | USA     | 55401    |
 | SUITE 560
 (1 row)
 I have this slated for 2.3, but hoping to fix for 2.2 and will push back
 when I do.  I think this can be corrected by updated the pagc_* tables
 packaged with tiger.  I'm hesitant to make the same change to the
 address_standardizer_data_us tables since I wanted to keep those
 compatible with what Steve had.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3259>
