[postgis-tickets] [PostGIS] #2817: Automated tests for address_standardizer
trac at osgeo.org
Sun Aug 23 23:49:53 PDT 2015
Reporter: robe | Owner: woobri
Type: task | Status: closed
Priority: medium | Milestone: PostGIS 2.2.0
Component: pagc_address_parser | Version: trunk
Resolution: fixed | Keywords:
Changes (by robe):
* status: new => closed
* resolution: => fixed
Comment:
I did this a couple of days go, but leverage the postgresql installcheck
machinery. It was much easier to do that than try to push it into runtest
which tries to install postgis etc, that address_standardizer doesn't
require.
So to test you need to for now
cd extensions/address_standardizer
make installcheck
Have this documented as well
Ticket URL: <https://trac.osgeo.org/postgis/ticket/2817#comment:1>
