[postgis-tickets] [PostGIS] #3264: Spurious edges in ST_ApproximateMedialAxis
PostGIS trac at osgeo.org
Tue Aug 25 05:26:11 PDT 2015
  Reporter:  strk     |      Owner:  strk
      Type:  defect   |     Status:  new
  Priority:  medium   |  Milestone:  PostGIS 2.2.0
 Component:  postgis  |    Version:  trunk
Resolution:           |   Keywords:
Comment (by vmo):
 Maybe checking the result would be better/easier to find a good tolerance.
 The medial axis points should all be at the same distance from the
 contour, so checking the distance of Approx Medial Axis segments ends and
 middle would provide a metric of the quality (min/max ~ 1, looking at the
 picture it would be ~ .5).
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3264#comment:3>
