[postgis-tickets] [PostGIS] #3265: ST_GetFaceEdge: ERROR: No edge (among 3) found to be defining geometry of face 2
trac at osgeo.org
Wed Aug 26 07:25:05 PDT 2015
face 2
Reporter: strk | Owner: strk
Type: defect | Status: closed
Priority: blocker | Milestone: PostGIS 2.2.0
Component: topology | Version: trunk
Resolution: fixed | Keywords:
Changes (by strk):
* status: new => closed
* resolution: => fixed
Comment:
I found the problem. The code finding the edge covering "next portion" of
ring was not early failing on first non-common vertex. I've also spotted
another bug which was failing to return a single clockwise edge as the
shell of a face (due to the "next edge finder" code not considering the
possibility of a closed edge).
No need to revert to original algorithm ! (slower)
Full test for all these cases added in 2.1 branch with r14006 and in 2.0
branch with r14008.
Trunk got fix and tests with r14007.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3265#comment:2>
