[postgis-tickets] [PostGIS] #2908: Cannot upgrade: cannot drop function st_summarystats(raster, integer, boolean) because other objects depend on it
PostGIS trac at osgeo.org
Thu Aug 27 04:28:22 PDT 2015
st_summarystats(raster,integer,boolean) because other objects depend on it
  Reporter:  strk                   |      Owner:  strk
      Type:  defect                 |     Status:  closed
  Priority:  medium                 |  Milestone:  PostGIS 2.2.0
 Component:  build/upgrade/install  |    Version:  trunk
Resolution:  fixed                  |   Keywords:  raster
Changes (by strk):
 * status:  new => closed
 * resolution:   => fixed
Comment:
 I can't reproduce this anymore, so will assume fixed.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/2908#comment:4>
