[postgis-tickets] [PostGIS] #3025: Analyze not creating spatial statistics on LineString Z geometry
trac at osgeo.org
Mon Feb 2 07:02:05 PST 2015
Reporter: rightway | Owner: pramsey
Type: defect | Status: closed
Priority: medium | Milestone: PostGIS 2.1.6
Component: postgis | Version: 2.1.x
Resolution: wontfix | Keywords: extents, analyze
Comment(by rightway):
Thanks, finally managed to create a valid linestringZ dataset and verified
that st_estimatedextent does work with it.
I guess that my only comment is that if the geometry isn't valid enough to
analyze then it would be helpful if the st_isvalid and st_isvalidreason
commands picked up this error. Either that or get the analyze to ignore
dodgy Z and M values and still work out the extents which is only a box2d
anyway.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/3025#comment:6>
