[postgis-tickets] [PostGIS] #3028: create extension postgis from unpackaged - ERROR: function st_intersection(raster, integer, geometry) does not exist
trac at osgeo.org
Mon Feb 2 07:26:49 PST 2015
Reporter: strk | Owner: robe
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.2.0
Component: raster | Version: trunk
Keywords: |
Comment(by strk):
But indeed I don't have it:
strk=# alter FUNCTION st_intersection (rast raster, band integer, geomin
geometry) security invoker;
Nor rtpostgis_upgrade.sql installs it for me, which is weird because I do
see the line adding it.
FOUND: the rtpostgis_upgrade.sql first drops it (as it changed signature
or something) then creates it and finally drops it again as "obsoleted"
(which evidently isn't).
It's dropped with lots of other functions on line 8698 of
rtpostgis_upgrade.sql for me as the final step. Initially dropped on line
532 and recreated on line 6417
Ticket URL: <http://trac.osgeo.org/postgis/ticket/3028#comment:4>
