[postgis-tickets] [PostGIS] #3028: create extension postgis from unpackaged - ERROR: function st_intersection(raster, integer, geometry) does not exist
trac at osgeo.org
Mon Feb 2 07:39:51 PST 2015
Reporter: strk | Owner: dustymugs
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.2.0
Component: raster | Version: trunk
Keywords: |
Comment(by strk):
Removing that function from the drop, next error raises:
ERROR: function st_intersection(raster, geometry) does not exist
This one is defined in a somewhat conflicting way, once with default
argument, one w/out.
I guess at runtime you'd get an "ambiguous" message when trying to call
the 2-argument version, shouldn't you ?
The complete list of suspicious functions:
https://github.com/postgis/postgis/blob/svn-
trunk/raster/rt_pg/rtpostgis_drop.sql.in#L53-L62
The two definitions of the next problematic one:
trunk/raster/rt_pg/rtpostgis.sql.in#L6366
trunk/raster/rt_pg/rtpostgis.sql.in#L6406
It needs some love to clean up duplications, obsolete some functions and
keep the others
Ticket URL: <http://trac.osgeo.org/postgis/ticket/3028#comment:7>
