[postgis-tickets] [PostGIS] #3026: Postgis 2.1 with 2 versions of Postgresql DB?
PostGIS trac at osgeo.org
Mon Feb 2 14:41:40 PST 2015
  Reporter:  renatab  |       Owner:  pramsey
      Type:  defect   |      Status:  closed
  Priority:  high     |   Milestone:  PostGIS 2.1.6
 Component:  postgis  |     Version:  2.1.x
Resolution:  invalid  |    Keywords:
Changes (by robe):
  * status:  new => closed
  * resolution:  => invalid
Comment:
 Renatab,
 This is something better asked on our mailing list which you can join
 here:
 http://lists.osgeo.org/mailman/listinfo/postgis-users
 I don't think this is a PostGIS issue.  As I recall both PostgreSQL 9.3
 and PostgreSQL 9.4 from Apt support PostGIS 2.1 since that is the latest
 version.  I haven't tried installing both on the same Ubuntu instance, but
 my guess is you installed the PostGIS for 9.4 but didn't for 9.3  which is
 why CREATE EXTENSION works fine on 9.4 and not 9.3.
 If there is anything wrong here, it's most likely a packaging issue or you
 simply did not install the PostGIS 9.3 extension.  Posting a note in the
 mailing list with exactly how you installed both would give us a better
 clue.  Might be we just need to amend the instructions now that 9.4 is
 out)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/3026#comment:3>
