[postgis-tickets] [PostGIS] #3030: ST_Boundary does not reduce dimensionality for empty geometries
PostGIS trac at osgeo.org
Mon Feb 2 21:22:07 PST 2015
 Reporter:  bladeoflight16  |       Owner:  pramsey
     Type:  defect          |      Status:  new
 Priority:  medium          |   Milestone:
Component:  postgis         |     Version:  2.1.x
 Keywords:                  |
 This query:
 SELECT ST_AsText(ST_Boundary(geom))
 FROM (VALUES ('POLYGON EMPTY'::GEOMETRY),
              ('MULTIPOLYGON EMPTY'::GEOMETRY),
              ('LINESTRING EMPTY'::GEOMETRY),
              ('MULTILINESTRING EMPTY'::GEOMETRY)
      ) g (geom);
 gives these results:
 'POLYGON EMPTY'
 'LINESTRING EMPTY'
 I generally expect ST_Boundary to return a geometry of one less dimension
 even if the geometry is an empty one. (I.e., I expect an empty linestring
 from a polygon input and an empty point for a linestring input.)
 (Posting this after being instructed to on the mailing list.)
 Confirmed using the following versions:
 POSTGIS="2.1.5 r13152" GEOS="3.3.3-CAPI-1.7.4" PROJ="Rel. 4.7.1, 23
 September 2009" GDAL="GDAL 1.9.0, released 2011/12/29" LIBXML="2.8.0"
 LIBJSON="UNKNOWN" RASTER
 and
 "POSTGIS="2.1.4 r12966" GEOS="3.4.2-CAPI-1.8.2 r3921" PROJ="Rel. 4.8.0, 6
 March 2012" GDAL="GDAL 1.9.2, released 2012/10/08" LIBXML="2.7.6"
 LIBJSON="UNKNOWN" RASTER"
Ticket URL: <http://trac.osgeo.org/postgis/ticket/3030>
