[postgis-tickets] [PostGIS] #2918: Use GeographicLib functions for ST_Azimuth, ST_Distance, ST_Project, ST_Length, ST_Perimeter and ST_Area
trac at osgeo.org
Sun Feb 8 15:23:19 PST 2015
Reporter: mwtoews | Owner: pramsey
Type: patch | Status: new
Priority: medium | Milestone: PostGIS 2.2.0
Component: postgis | Version: trunk
Keywords: |
Comment(by mwtoews):
I've merged the latest `svn-trunk` to the pull request, so it should be
all caught up. There are a few other misc. changes that caught up, such as
using math constants for fractions of PI, and wording in the manual.
I'm neutral for a hybrid approach. If such approach were implemented for
inverse geodesic measures (distance), it would switch methods where there
are known precision issues (e.g.) >0.1 mm error, and/or the difference of
performance is negligible. It would take a bit more investigating to find
out how to implement these limits (or to find out if that approach is too
complicated). Area and direct geodesic (ST_Project) methods should
definitely use GeographicLib.
At any rate, the user has the choice of using the `use_spheroid=true`
option if they don't want to compromise speed. But if they want to use
more expensive and accurate geodesic methods, then they can choose to have
it with `use_spheroid=false`.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2918#comment:23>
