[postgis-tickets] [PostGIS] #3031: "POINT EMPTY" as WKB defaults to "MULTIPOINT EMPTY" when restoring with copy and failing validation
trac at osgeo.org
Sun Feb 8 16:22:51 PST 2015
Reporter: jeanchristophesaville | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.1.6
Component: postgis | Version: 2.1.x
Keywords: POINT EMPTY , MULTIPOINT EMPTY |
Comment(by pramsey):
Every type except point as a WKB representation that goes
endian[byte] + typenumber[integer] + numpoints[integer]
those are the patterns you're seeing for the other types. endian, type,
and then a zero, indicating the object has zero elements or zero points
trouble is, the wkb for point is
endian[byte] + typenumber[integer] + x[double} + y[double]
there's nowhere to put in the information that the point is actually empty
our internal representation is slightly fluffier, but in order to retain
backwards compatibility with postgis 1.x when we moved to 2.x we kept the
same canonical representation... this allowed things like apps (mapserver,
geoserver, fme, etc) to keep on functioning w/o changes against 2.0 which
was great. the only problem we've had is this compromise we had to make on
POINT EMPTY
probably the "best" fix would be to stop creating POINT EMPTY in *any*
eventuality and always create a MULTIPOINT EMPTY if called upon for an
empty pointy thing
Ticket URL: <http://trac.osgeo.org/postgis/ticket/3031#comment:3>
