[postgis-tickets] [PostGIS] #3034: ST_AsTWKBagg does not check the input precision
trac at osgeo.org
Wed Feb 11 11:01:20 PST 2015
Reporter: javisantana | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone:
Component: postgis | Version: 2.1.x
Keywords: |
running the following query
test_postgis=# select ST_AsTWKBagg(st_makepoint(10,10), 10) from
generate_series(1, 10);
ERROR: Output TWKB is not the same size as the allocated buffer
(precalculated size:31, allocated size:33)
if you use st_astwkb you get
test_postgis=# select ST_AsTWKB(st_makepoint(10,10), 10);
ERROR: precision cannot be more than 7
ST_AsTWKBagg method lacks of checking (see attached path) but I'm pretty
sure that check should be done at encoding level.
Also I'm not sure why the precision is limited to 7
Ticket URL: <http://trac.osgeo.org/postgis/ticket/3034>
