[postgis-tickets] [PostGIS] #3032: Travis CI error in before_install: libgdal-dev : Depends: libgdal1h
PostGIS trac at osgeo.org
Mon Feb 16 15:15:37 PST 2015
  Reporter:  mwtoews    |       Owner:  robe
      Type:  patch      |      Status:  closed
  Priority:  medium     |   Milestone:  Management 2.0
 Component:  buildbots  |     Version:  trunk
Resolution:  fixed      |    Keywords:
Changes (by mwtoews):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 Looks like it's working. I've also tested on another repo to make sure
 there are fails too for any modifications to the source in one of regress,
 liblwgeom, or doc. So while there are certainly other installations of
 PostGIS on the test machines, these should not influence the outcome of
 the testing of the !GitHub/Travis CI build.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/3032#comment:3>
