[postgis-tickets] [PostGIS] #3039: 2.1.2--2.2.0dev: ERROR: operator ~ already exists
trac at osgeo.org
Tue Feb 17 09:15:04 PST 2015
Reporter: strk | Owner: strk
Type: defect | Status: assigned
Priority: blocker | Milestone: PostGIS 2.1.6
Component: build/upgrade/install | Version: 2.1.x
Keywords: |
Changes (by strk):
* cc: robe (added)
* version: trunk => 2.1.x
* milestone: => PostGIS 2.1.6
Comment:
For a start I've committed a fix for the soft-upgrade problem, not re-
enabling the COMMUTATOR but pretending nothing changed since 2.0.0. This
was done with r13229 in trunk (2.2.0dev) and r13228 in 2.1 branch
(2.1.6dev).
I'll wait some time for your comments before proceeding with un-commenting
the COMMUTATOR part of those old operators, to make newly installed 2.1.6
and 2.2.0 at least as correct as 2.1.1 was.
2.1.2 to 2.1.5 new installs would still be incorrect and no soft-upgrade
would fix them unless some further step is taken.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/3039#comment:5>
