[postgis-tickets] [PostGIS] #3041: Cunit 2.1-3 breaks testing
trac at osgeo.org
Wed Feb 18 13:57:37 PST 2015
Reporter: pramsey | Owner: pramsey
Type: defect | Status: new
Priority: high | Milestone: PostGIS 2.0.7
Component: postgis | Version: 2.1.x
Keywords: |
The internal structures Cunit uses change in the patch release 2.1-3,
resulting in the cu_tester program segfaulting. The solution is the re-
write the test setup code to use the cunit functions instead of building
static internal structures.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/3041>
