[postgis-tickets] [PostGIS] #3046: topology.GetRingEdges return wrong ring when edge.next_left/right = edge
PostGIS trac at osgeo.org
Fri Feb 20 00:38:24 PST 2015
  Reporter:  remic     |       Owner:  strk
      Type:  defect    |      Status:  closed
  Priority:  medium    |   Milestone:
 Component:  topology  |     Version:  2.1.x
Resolution:  invalid   |    Keywords:
Changes (by strk):
  * status:  new => closed
  * resolution:  => invalid
Comment:
 It's not an error. The function lists the edge being walked on and the
 direction. By starting with a negative value you request to walk on that
 edge backward, from its right side. A left turn is taken on every node.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/3046#comment:1>
