[postgis-tickets] [PostGIS] #1498: ST_CrossProduct ?
trac at osgeo.org
Fri Feb 20 04:02:37 PST 2015
Reporter: strk | Owner: pramsey
Type: enhancement | Status: new
Priority: low | Milestone: PostGIS Future
Component: postgis | Version: trunk
Keywords: |
Comment(by remic):
Function (expect a ring of signed edge)
DROP FUNCTION IF EXISTS topology.ST_SignedArea( ring_of_edges INT[] ) ;
CREATE OR REPLACE FUNCTION topology.ST_SignedArea( ring_of_edges INT[] ,
OUT signedArea FLOAT)
AS
$BODY$
/** @brief given a ring (an ordered set of signed edge_id),
compute the sum of angles between nodes
DECLARE
BEGIN
WITH input_data AS (
SELECT r.ordinality, r.value AS s_edge_id, (count(*)
over(partition by abs(r.value)) <>2) as is_simple
FROM rc_unnest_with_ordinality(ring_of_edges) as r
,joined_to_edge AS (
SELECT ordinality, s_edge_id, edge_id, dmp.geom as
pt_geom, path[1] as path
FROM input_data as id
LEFT OUTER JOIN bdtopo_topological.edge_data as ed
ON (abs(id.s_edge_id) = ed.edge_id)
, ST_DumpPoints(geom) AS dmp
WHERE s_edge_id <0 AND is_simple = TRUE
UNION ALL
pt_geom, -path[1] as path
WHERE s_edge_id >0 AND is_simple = TRUE
,getting_next_node AS (
SELECT ordinality, s_edge_id , pt_geom as pt,
COALESCE(lead(pt_geom,1) OVER(w) , first(pt_geom) OVER(w )) as n_pt
FROM joined_to_edge
WINDOW w AS (ORDER BY ordinality ASC, path ASC)
SELECT sum( (ST_X(n_pt)-ST_X(pt)) * (ST_Y(n_pt)+ST_Y(pt) )/2.0
) INTO signedArea
FROM getting_next_node ;
RETURN ;
END ;
$BODY$
LANGUAGE plpgsql IMMUTABLE STRICT;
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1498#comment:7>
