[postgis-tickets] [PostGIS] #3048: Use Squared Distance instead of Distance in Simplify
trac at osgeo.org
Fri Feb 20 09:06:40 PST 2015
Reporter: pramsey | Owner: pramsey
Type: defect | Status: reopened
Priority: high | Milestone: PostGIS 2.1.6
Component: postgis | Version: 2.1.x
Resolution: | Keywords:
Changes (by strk):
* status: closed => reopened
* resolution: fixed =>
Comment:
I was wrong, as of r329 only variable _names_ had the "sqared" label, but
the implementation was bogus. The fix, later, went the way to use flat
distance rather than squared one.
Anyway, simplify tests are failing for me, both in unit test and regress.
Am I the only one ?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/3048#comment:4>
