[postgis-tickets] [PostGIS] #3060: loader_load_staged_data relying on undefined behaviour when generating column lists
trac at osgeo.org
Thu Feb 26 07:02:06 PST 2015
column lists
Reporter: gibreel | Owner: robe
Type: defect | Status: new
Priority: medium | Milestone:
Component: tiger geocoder | Version: 2.1.x
Keywords: loader |
The loader_load_staged_data function assumes that select statement for
column names will produce the same sequence for both the source and
destination tables. While it might, such ordering behaviour isn't
guaranteed as the error below shows.
The simple fix is to add 'order by column_name' to both queries. Patch
attached.
Trace output below:
+ psql -c 'ALTER TABLE tiger_staging.county RENAME geoid TO cntyidfp;
SELECT loader_load_staged_data(lower('\''county'\''),
lower('\''county_all'\''));'
NOTICE: INSERT INTO
tiger_data.county_all(statefp,countyfp,countyns,cntyidfp,name,namelsad,lsad,classfp,mtfcc,csafp,cbsafp,metdivfp,funcstat,aland,awater,intptlat,intptlon,the_geom)
SELECT
statefp,countyfp,countyns,name,namelsad,lsad,classfp,mtfcc,csafp,cbsafp,metdivfp,funcstat,aland,awater,intptlat,intptlon,the_geom,cntyidfp
FROM tiger_staging.county;
CONTEXT: SQL function "loader_load_staged_data" statement 1
ERROR: column "awater" is of type double precision but expression is of
type character varying
LINE 1: ...mtfcc,csafp,cbsafp,metdivfp,funcstat,aland,awater,intptlat,i...
HINT: You will need to rewrite or cast the expression.
QUERY: INSERT INTO
SELECT
CONTEXT: PL/pgSQL function loader_load_staged_data(text,text,text[]) line
24 at EXECUTE statement
Ticket URL: <http://trac.osgeo.org/postgis/ticket/3060>
