[postgis-tickets] [PostGIS] #3064: Regression failures when building against 9.2 for windows
PostGIS trac at osgeo.org
Fri Feb 27 18:17:30 PST 2015
 Reporter:  robe     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 1.5.9
Component:  postgis  |     Version:  1.5.X
 Keywords:           |
 I'm not sure if this is a problem with the regression tests or something
 amiss with 9.2.
  PostgreSQL 9.2.10, compiled by Visual C++ build 1600, 64-bit
  Postgis 1.5.8 - 2015-02-28 02:02:11
    GEOS: 3.4.2-CAPI-1.8.2 r3924
    PROJ: Rel. 4.8.0, 6 March 2012
 Running tests
  loader/Point.............. ok
  loader/PointM.............. ok
  loader/PointZ.............. ok
  loader/MultiPoint.............. ok
  loader/MultiPointM.............. ok
  loader/MultiPointZ.............. ok
  loader/Arc.............. ok
  loader/ArcM.............. ok
  loader/ArcZ.......... ok
  loader/Polygon.............. ok
  loader/PolygonM.............. ok
  loader/PolygonZ.............. ok
  regress. ok
  regress_index. ok
  regress_management. ok
  regress_index_nulls. ok
  lwgeom_regress. ok
  regress_lrs. ok
  removepoint. ok
  setpoint. ok
  simplify. ok
  snaptogrid. ok
  summary. ok
  affine. ok
  wkt. ok
  measures. ok
  long_xact. ok
  ctors. ok
  sql-mm-serialize. ok
  sql-mm-circularstring. ok
  sql-mm-compoundcurve. ok
  sql-mm-curvepoly. ok
  sql-mm-general. ok
  sql-mm-multicurve. ok
  sql-mm-multisurface. ok
  geojson. ok
  gml. ok
  svg. ok
  kml. ok
  in_gml. failed (diff expected obtained: /tmp/pgis_reg_3852/test_40_diff)
  in_kml. failed (diff expected obtained: /tmp/pgis_reg_3852/test_41_diff)
  polygonize. ok
  regress_ogc. failed (diff expected obtained:
 /tmp/pgis_reg_3852/test_43_diff)
  regress_ogc_cover. ok
  regress_ogc_prep. ok
  regress_bdpoly. ok
  regress_proj. ok
  dumppoints. ok
  wmsservers. ok
  tickets. ok
  regress_buffer_params. ok
  hausdorff. ok
 Run tests: 52
 Failed: 3
 make[1]: Leaving directory
 `/projects/postgis/branches/postgis-1.5.8/regress'
 Diffs attached.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/3064>
