[postgis-tickets] [PostGIS] #3065: Spatial index on LINESTRING not used under some circumstances
trac at osgeo.org
Sat Feb 28 04:49:33 PST 2015
Reporter: realityexists | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone:
Component: postgis | Version: 2.1.x
Keywords: |
POSTGIS="2.1.5 r13152" GEOS="3.4.2-CAPI-1.8.2 r3924" PROJ="Rel. 4.8.0, 6
March 2012" GDAL="GDAL 1.11.1, released 2014/09/24" LIBXML="2.7.8"
LIBJSON="UNKNOWN" RASTER
PostgreSQL 9.3.6, compiled by Visual C++ build 1600, 64-bit
Windows 7 SP1 x64
I have a complex query that intersects linestrings with polygons. It first
builds a temp table of the linestrings with a GIST index on the linestring
column, then does the main intersection query, which normally takes ~20
minutes. With a particular set of linestrings this GIST index is not used
(as shown by the EXPLAIN output) and the main query takes nearly 3 hours.
The temp table was created like this:
CREATE TEMP TABLE _sia_segment
AS SELECT ST_MakeLine(start_pos::geometry, end_pos::geometry)::geography
AS line
, NULL::integer AS segment_length, ... other stuff ...
FROM ...
UPDATE _sia_segment
SET segment_length = ST_Length(line);
CREATE INDEX ix__sia_segment_line ON _sia_segment USING GIST (line);
Also, not sure if it's related, but the CREATE INDEX command outputs
messages like this:
DEBUG: picksplit method for column 1 of index "ix__sia_segment_line"
failed
HINT: The index is not optimal. To optimize it, contact a developer, or
try to use the column as the second one in the CREATE INDEX command.
If I run CREATE INDEX before the UPDATE then the UPDATE also outputs those
messages.
I found that if I move the ST_Length() into the original SELECT statement
the problem goes away - the index is used. So my original problem is
solved, but if anyone wants to investigate the PostGIS behaviour I can try
to create a repro. It should be easy for the picksplit error, though not
so easy for the original problem (index not used).
Also, the problem only occurred when the CREATE TEMP TABLE and the main
intersection query were done inside a transaction. Outside of a
transaction the index was used just fine, despite the picksplit error. So
the circumstances are quite particular, but reliably reproducible in my
database.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/3065>
