[postgis-tickets] [PostGIS] #2227: Visvalingam line generalization function
trac at osgeo.org
Mon Jan 12 13:57:45 PST 2015
Reporter: strk | Owner: nicklas
Type: enhancement | Status: new
Priority: medium | Milestone: PostGIS 2.2.0
Component: postgis | Version: trunk
Keywords: |
Comment(by nicklas):
About naming:
Maybe ST_Visvalingam is better, but it doesn't say anything about what the
function is doing without knowledge of Mr Visvalingam's work. It would be
like calling ST_Simplify something with DP. But I also see that
EffectiveArea doesn't say anything if you don't now the concept. I have no
real opinion here so we can change it. Shall we?
About 0 a threashold:
Yes of course that makes sense. But we also want a way to get back all
points. We can make a distinction between gicing 0 as threashold and don't
give any second parameter at all (a negative default value is maybe the
easiest to avoid 2 signatures)). But to get really 0.0000 units effective
area will be quite rare (except vertical and horizontal lines), so giving
0.01 (or whatever depending on what unit is used) will often give more of
the desired effect.
About first point last point I think you refered to #1698, #1987 and
#2093.
I put a comment in #2093 about that.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2227#comment:7>
