[postgis-tickets] [PostGIS] #2227: Visvalingam line generalization function
PostGIS trac at osgeo.org
Thu Jan 15 01:35:46 PST 2015
 Reporter:  strk         |       Owner:  nicklas
     Type:  enhancement  |      Status:  new
 Priority:  medium       |   Milestone:  PostGIS 2.2.0
Component:  postgis      |     Version:  trunk
 Keywords:               |
Comment(by nicklas):
 Yes, that could be a good idea to extend ST_Simplify. Why not?
 Only thing that might confuse people is that the distance vs area
 parameter gives very different result with the same value. But as long as
 the old algorithm is the default they will need to read the doc anyway to
 find out about the options.
 You are right that it doesn't make sense to drop vertices in a function
 named SetEffectiveArea.
 One question is if the Visvalingam version should have an option not to
 include the effective area but just remove vertices like ST_Simplify? Will
 there be people using it that want to preserver whatever they have in M?
 It also uses som space to include an extra dimmension. It is written so it
 is easy not to write any M-value.
 About unit-tests and regress-tests that is on my list. Doc is committed
 but looks ugly as it stands. I will look at it.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2227#comment:10>
