[postgis-tickets] [PostGIS] #2573: Have ST_3DIntersects to recognize Triangle as a type
trac at osgeo.org
Sun Jan 18 09:36:06 PST 2015
Reporter: smathermather | Owner: robe
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.2.0
Component: documentation | Version: 2.1.x
Keywords: |
Comment(by robe):
I made a change to the doco at r13183
Check it out and see if it makes sense
http://postgis.net/docs/manual-dev/ST_3DIntersects.html
One thing I am not sure about is how SFCGAL treats closed surfaces. As I
recall I think it treats it as a solid and so ST_3DIntersects for closed
polyhedral surfaces may return a different answer than what the built-in
ST_3DIntersects returns. Also the documentation was a bit out-dated in
that lwgeom only sT_3DIntersects does support polygons and polyhedral
surfaces (I think this may have been a limitation in early 2.0, but got
changed at release time thought it hasn't been very stress tested). I'll
have to verify that before I backport.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2573#comment:6>
