[postgis-tickets] [PostGIS] #2573: Have ST_3DIntersects to recognize Triangle as a type
PostGIS trac at osgeo.org
Mon Jan 19 16:19:21 PST 2015
 Reporter:  smathermather  |       Owner:  robe
     Type:  defect         |      Status:  new
 Priority:  medium         |   Milestone:  PostGIS 2.2.0
Component:  documentation  |     Version:  2.1.x
 Keywords:                 |
Comment(by robe):
 vmo,
 Hmm I might have been testing by extruding a polygon then but to be
 honest, I was testing ST_3DIntersection.  So are you saying that if you
 say ST_Extrude a rectangle so it becomes a solid polyhedral surface, then
 ST_3DIntersects would treat it as solid? even though the ST_AsText gives
 you a PolyhedralSurface indistinguishable from the one you built from
 text?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2573#comment:8>
