[postgis-tickets] [PostGIS] #3026: Postgis 2.1 with 2 version of Postgresql DB?
trac at osgeo.org
Fri Jan 30 00:42:51 PST 2015
Reporter: renatab | Owner: pramsey
Type: defect | Status: new
Priority: high | Milestone: PostGIS 2.1.6
Component: postgis | Version: 2.1.x
Keywords: |
I don't know if this is a problem or something.
I installed on an Ubuntu 14.04 server Postgis + Postresql with the infos
collected in this page and without any errors at all:
http://trac.osgeo.org/postgis/wiki/UsersWikiPostGIS21UbuntuPGSQL93Apt
But, at the end, I discovered that there are TWO postgresql inside this
server. There are two Postgresql directories (9.3 and 9.4) inside
/etc/postgresql and using /etc/init.d/postgresql status I get:
9.3/main (port 5432): online
9.4/main (port 5433): online
I don't think this is correct (and I don't know what to do now...) or...
is there a reason for two releases of postgresql installed with Postgis
2.1?
Thank you very much,
Renata (ArpaVeneto- Italy)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/3026>
