[postgis-tickets] [PostGIS] #3027: postgis.control not installed without raster support
PostGIS trac at osgeo.org
Fri Jan 30 10:38:54 PST 2015
 Reporter:  springmeyer  |       Owner:  pramsey
     Type:  defect       |      Status:  new
 Priority:  medium       |   Milestone:
Component:  postgis      |     Version:  2.1.x
 Keywords:               |
 Apologies if I am misunderstanding something, however I'm seeing that:
 - `postgis.control` needs to be installed into
 `share/postgresql/extension/` in order to be able to run `psql
 template_postgis -c "CREATE EXTENSION postgis;"` without an error.
 - and `postgis.conrol` is only installed if postgis raster support is
 enabled.
 This seems very odd to me: you should be able to use PostGIS without gdal
 support built in without the `CREATE EXTENSION postgis;` function broken.
 Right? Or am I missing something obvious? I think this is the root of the
 confusion behind https://github.com/Homebrew/homebrew/issues/33566
 (basically homebrew can't figure out how to package working postgis
 install as a binary because they likely did not build the binary with
 raster support).
 It looks like this has been like this for a while:
 https://github.com/postgis/postgis/commit/75eea67e6ec68fdd2de1819e7064d998183cf4a8.
 Would it be feasible to still install `postgis.control` without needing
 raster support?
 See also #2356 which may be related
Ticket URL: <http://trac.osgeo.org/postgis/ticket/3027>
