[postgis-tickets] [PostGIS] #2988: [raster] check_gdal regress fails when POSTGIS_GDAL_ENABLED_DRIVERS set
trac at osgeo.org
Sat May 2 09:39:24 PDT 2015
Reporter: robe | Owner: dustymugs
Type: defect | Status: closed
Priority: medium | Milestone: PostGIS 2.1.8
Component: raster | Version: 2.1.x
Resolution: wontfix | Keywords:
Changes (by dustymugs):
* status: assigned => closed
* resolution: => wontfix
Comment:
I don't believe this is something that can be fixed in versions < 2.2 due
to the inability to change PostgreSQL's env variables. This isn't an issue
in 2.2 due to the use of GUCs.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2988#comment:7>
