[postgis-tickets] [PostGIS] #3110: Use 64bit integers for identifiers
trac at osgeo.org
Fri May 8 03:18:18 PDT 2015
Reporter: strk | Owner: strk
Type: enhancement | Status: new
Priority: medium | Milestone: PostGIS 2.2.0
Component: topology | Version: trunk
Keywords: |
Topology primitive tables are created with 32bit integer identifiers.
This ticket is to use 64bit integers instead.
Note that such change would also affect the relation table and the
TopoElement and TopoElementArray domains.
An upgrade path should also be provided to alter existing topologies.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/3110>
