[postgis-tickets] [PostGIS] #897: Ability to output X3D using GeoCoordinates (just GD WE) (was: Ability to output X3D using GeoCoordinates)
PostGIS trac at osgeo.org
Sat May 9 16:02:24 PDT 2015
  Reporter:  robe     |      Owner:  robe
      Type:  defect   |     Status:  closed
  Priority:  high     |  Milestone:  PostGIS 2.2.0
 Component:  postgis  |    Version:  trunk
Resolution:  fixed    |   Keywords:  history
Changes (by robe):
 * status:  new => closed
 * keywords:   => history
 * resolution:   => fixed
Old description:
> This would be another proto version of ST_AsX3D that takes true/false
> boolean whether to output coordinates in GeoCoordinate instead of
> standard X3D coordinates.
> Of course it will need to have a known SRID.  For starters just going to
> transform to  GD (WGS 84 lon lat) (will not support the UTM ones yet
> since that would require mapping to their naming)
> Hope to get this in in PostGIS 2.0, but might have to wait till 2.1.
> See for details:
> http://www.web3d.org/x3d/wiki/index.php/X3D_Earth_public_site
New description:
 I encoded this in the option argument.
 2 means geocoordinates WGS 84 long,lat
 3 means geocordinates WGS 84 lat,long
 and is only supported if srid = 4326 and will not bother doing a
 transformation if a different srid.
 UTM and GC support I will push to #2840.
 See for details:
Comment:
 This is related to #2840.  Revising this and marking it as done at r13485.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/897#comment:2>
