[postgis-tickets] [PostGIS] #3114: debbie can't find gdal
trac at osgeo.org
Sat May 9 16:39:09 PDT 2015
Reporter: robe | Owner: robe
Type: defect | Status: new
Priority: blocker | Milestone: Management 2.0
Component: management | Version: 2.1.x
Resolution: | Keywords:
Comment (by robe):
error is showing this:
checking for library containing GDALAllRegister... no
configure: error: could not find GDAL
before it would just show
checking for library containing GDALAllRegister... none required
checking for library containing OGRRegisterAll... none required
checking for library containing GDALFPolygonize... none required
GDAL version is still being picked up however and I tried both GDAL 1.11
branch and trunk. I'm just going to try to flush out GDAL build folder and
rebuild.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/3114#comment:1>
