[postgis-tickets] [PostGIS] #3117: Add support for SFCGAL 1.1
trac at osgeo.org
Mon May 11 06:10:37 PDT 2015
Reporter: vmo | Owner: colivier
Type: enhancement | Status: new
Priority: medium | Milestone: PostGIS 2.2.0
Component: sfcgal | Version: 2.1.x
Resolution: | Keywords:
Comment (by vmo):
Here is a summary of the attached patch.
In doc/reference_sfcgal.xml
- added doc for ST_3DDifference, ST_3DUnion, ST_Volume
- added doc for ST_MakeSolid and ST_IsSolid that are pure postgis
functions to set/get the solid flag
In postgis/lwgeom_backend_api.c
- added backend switch for difference and union
In postgis/lwgeom_geos.h and postgis/lwgeom_geos.c
- changed the name of difference and union
- exposed those renamed functions
In postgis/lwgeom_sfcgal.c
- added difference, union, volume
- added makesolid and issolid
In postgis/sfcgal.sql.in
- added ST_3DDifference, ST_3DUnion and ST_Volume
- added ST_MakeSolid and ST_IsSolid
In regress/sfcgal/concave_hull.sql
- fixed test failure caused by insufficient tolerance
In regress/sfcgal/empty.sql, regress/sfcgal/empty_expected,
regress/sfcgal/regress_ogc.sql and regress/sfcgal/regress_ogc_expected
- fixed test to avoid failure on equivalent representation of a polygon
(different starting point for a ring)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3117#comment:1>
