[postgis-tickets] [PostGIS] #2531: Autogenerate the extension unpackaged script
PostGIS trac at osgeo.org
Mon May 11 08:37:19 PDT 2015
  Reporter:  robe                   |      Owner:  strk
      Type:  enhancement            |     Status:  closed
  Priority:  medium                 |  Milestone:  PostGIS 2.2.0
 Component:  build/upgrade/install  |    Version:  trunk
Resolution:  fixed                  |   Keywords:
Changes (by strk):
 * status:  new => closed
 * resolution:   => fixed
Comment:
 I'll consider this done. The tiger geocoder I don't usually build so no
 idea if it can be automated in the same way. If you think so (and that it
 should) please file a new ticket.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2531#comment:7>
