[postgis-tickets] [PostGIS] #1890: Configure finds sometimes older libraries
trac at osgeo.org
Mon May 11 08:53:08 PDT 2015
Reporter: janh | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.2.0
Component: postgis | Version: 2.0.x
Resolution: | Keywords: Non-standard Configure
Comment (by strk):
Are you seeing this problem under liblwgeom/ or under postgis/ or where ?
Could you show a build line as an example ?
Theoretically the local path should be listed as first one with -I from
CPPFLAGS
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1890#comment:4>
