[postgis-tickets] [PostGIS] #2748: Deprecate all functions with underscore_names rather than CamelCase
trac at osgeo.org
Mon May 11 10:10:01 PDT 2015
Reporter: strk | Owner: strk
Type: task | Status: new
Priority: high | Milestone: PostGIS 2.2.0
Component: postgis | Version: trunk
Resolution: | Keywords:
Comment (by strk):
r13488 deprecates ST_Point_Inside_Circle (in favor of
ST_PointInsideCircle), left over:
- ST_Length2d_Spheroid(geometry,spheroid) -- should it be
ST_2DLengthSpheroid ? We have ST_LengthSpheroid and ST_3DLengthSpheroid
- ST_Locate_Between_Measures(geometry,float8,float8) -- is already
advertised as deprecated, using NOTICE (rather than WARNING). Results seem
incompatible with any existing name so cannot be changed to an SQL wrapper
(unless Paul knows how).
- ST_Locate_Along_MEasure(geometry,float8,float8) -- is already
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2748#comment:10>
