[postgis-tickets] [PostGIS] #3118: Can't upgrade 2.2.0dev to 2.2.0devnext
trac at osgeo.org
Fri May 15 02:05:28 PDT 2015
Reporter: strk | Owner: dustymugs
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.2.0
Component: raster | Version: trunk
Keywords: |
strk=# alter extension postgis update to '2.2.0devnext';
ERROR: cannot drop function _raster_constraint_nodata_values(raster)
because other objects depend on it
DETAIL: constraint enforce_nodata_values_r on table areas depends on
HINT: Use DROP ... CASCADE to drop the dependent objects too.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/3118>
