[postgis-tickets] [PostGIS] #3118: Can't upgrade 2.2.0dev to 2.2.0devnext
trac at osgeo.org
Fri May 15 07:54:50 PDT 2015
Reporter: strk | Owner: dustymugs
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.2.0
Component: raster | Version: trunk
Resolution: | Keywords:
Comment (by strk):
This patch for run_test.pl makes it reproduce the issue on "make check"
(or whenever it is called with switches --upgrade and --raster):
http://strk.keybit.net/tmp/extended_upgrade_test.patch
Ticket URL: <http://trac.osgeo.org/postgis/ticket/3118#comment:5>
