[postgis-tickets] [PostGIS] #2688: make check RUNTESTFLAGS=--extension can't run on debbie
PostGIS trac at osgeo.org
Sun May 17 20:34:28 PDT 2015
  Reporter:  robe       |      Owner:  robe
      Type:  defect     |     Status:  new
  Priority:  medium     |  Milestone:  Management 2.0
 Component:  buildbots  |    Version:  2.1.x
Resolution:             |   Keywords:
Comment (by robe):
 strk -- how do I get this thing to not try to install in protected areas?
 Get this error now on debbie when I try to install
 make[1]: Entering directory
 `/var/lib/jenkins/workspace/postgis/branches/2.2/liblwgeom'
 /bin/bash ../libtool --mode=install /bin/bash ../install-sh liblwgeom.la
 "/usr/local/lib/liblwgeom.la"
 libtool: install: /bin/bash ../install-sh .libs/liblwgeom-2.2.0dev.so
 /usr/local/lib/liblwgeom-2.2.0dev.so
 cp: cannot create regular file `/usr/local/lib/_inst.27454_': Permission
 denied
 make[1]: *** [install-liblwgeom] Error 1
 make[1]: Leaving directory
 make: *** [install] Error 1
 Build step 'Execute shell' marked build as failure
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2688#comment:5>
