[postgis-tickets] [PostGIS] #3122: Topology totopgeom crashes on PostgreSQL 9.5
trac at osgeo.org
Tue May 19 10:34:35 PDT 2015
Reporter: robe | Owner: strk
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 2.2.0
Component: topology | Version: trunk
Keywords: |
Just had debbie rebuild latest snapshot of 9.5 and regress on 2.2, and get
this:
http://debbie.postgis.net:8080/view/PostGIS/job/PostGIS_Regress_PGDEV_Weekly/149/console
The first crash is in totopogeom. I suspect the others might be just
cause postgres didn't restart in time.
regress/totopogeom .. failed (diff expected obtained:
/var/lib/jenkins/workspace/postgis/regress_pgdev/tmp/2_2_pg9.5w64/test_36_diff)
--- regress/totopogeom_expected 2014-04-26 22:51:51.000000000 -0700
/var/lib/jenkins/workspace/postgis/regress_pgdev/tmp/2_2_pg9.5w64/test_36_out
2015-05-19 10:12:46.000000000 -0700
@@ -21,27 +21,7 @@
POINT(0 0)|t
LINESTRING(0 10,10 10)|t
POLYGON((0 20,10 20,5 30,0 20),(2 22,8 22,5 28,2 22))|t
-MULTIPOINT(0 -10,5 -10)|t
-MULTILINESTRING((-1 10,-10 10),(-10 8,-2 9))|t
-MULTIPOLYGON(((100 20,110 20,105 30,100 20),(102 22,108 22,105 28,102
22)),((80 20,90 20,90 60,80 20)))|t
-GEOMETRYCOLLECTION(POINT(-100 -100),LINESTRING(-100 -90,-90
-90),POLYGON((-100 -80,-90 -80,-95 -70,-100 -80),(-98 -78,-92 -78,-95
-72,-98 -78)),MULTIPOINT(-100 -110,-95 -110),LINESTRING
EMPTY,MULTILINESTRING((-101 -90,-110 -90),(-110 -92,-102
-91)),MULTIPOLYGON(((0 -80,10 -80,5 -70,0 -80),(2 -78,8 -78,5 -72,2
-78)),((-20 -80,-10 -80,-10 -40,-20
-80))))|GEOMETRYCOLLECTION(MULTIPOLYGON(((-100 -80,-95 -70,-90 -80,-100
-80),(-98 -78,-92 -78,-95 -72,-98 -78)),((0 -80,5 -70,10 -80,0 -80),(2
-78,8 -78,5 -72,2 -78)),((-20 -80,-10 -40,-10 -80,-20
-80))),MULTILINESTRING((-110 -92,-102 -91),(-101 -90,-110 -90),(-100
-90,-90 -90)),MULTIPOINT(-100 -110,-100 -100,-95 -110))
-MULTIPOINT EMPTY
-MULTIPOINT EMPTY
-MULTILINESTRING EMPTY
-MULTIPOLYGON EMPTY
-MULTIPOLYGON EMPTY
-GEOMETRYCOLLECTION EMPTY
-tolerance_1|0.5
-tolerance_topo_1|0.5
-tolerance_0|0
-custom_search_path|0
-#1790.1|0|0
-#1790.2|0|0
-#1790.3|0|0
-#1968.1|0
-#1968.2|0
-tgup1.1|5|100|1
-tgup1.2|5|200|2
-tgup1.3|5|200|4
-Topology 'tt' dropped
+server closed the connection unexpectedly
+ This probably means the server terminated abnormally
+ before or while processing the request.
+connection to server was lost
regress/droptopology .. failed (diff expected obtained:
/var/lib/jenkins/workspace/postgis/regress_pgdev/tmp/2_2_pg9.5w64/test_37_diff)
--- regress/droptopology_expected 2014-04-26 22:51:51.000000000
-0700
/var/lib/jenkins/workspace/postgis/regress_pgdev/tmp/2_2_pg9.5w64/test_37_out
@@ -1,6 +1 @@
-t
-t
-t
-t
-Topology 't1' dropped
-Topology 't2' dropped
+psql: FATAL: the database system is in recovery mode
regress/droptopogeometrycolumn .. failed (diff expected obtained:
/var/lib/jenkins/workspace/postgis/regress_pgdev/tmp/2_2_pg9.5w64/test_38_diff)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/3122>
