[postgis-tickets] [PostGIS] #3122: Topology totopgeom crashes on PostgreSQL 9.5
PostGIS trac at osgeo.org
Fri May 22 19:42:11 PDT 2015
  Reporter:  robe      |      Owner:  strk
      Type:  defect    |     Status:  new
  Priority:  blocker   |  Milestone:  PostGIS 2.2.0
 Component:  topology  |    Version:  trunk
Resolution:            |   Keywords:  pg9.5
Comment (by robe):
 Just reran debbie, and Tom's fix noted here
 > Since May 9th our Debian build bot has been crashing on one of our
 > regression tests.
 > I tried the same exercise on my Mingw-w64 GCC 4.8.3 (with latest
 PostgreSQL
 > 9.5 - (dated 5/22) and also have crashing in same spot.
 > I isoloated the offending query in PostGIS to this:
 > with inp as ( select 'MULTIPOINT((0 -10),(5 -10))' ::geometry as g)
 > select St_AsText(g), ST_Equals(totopogeom(g, 'tt', 1)::geometry, g) from
 > inp;
 > Which produces a gdb backtrace:
 > Program received signal SIGSEGV, Segmentation fault.
 > [Switching to Thread 4252.0x3cf4]
 > array_contain_compare (array1=array1(at)entry=0xdd94200,
 > array2=array2(at)entry=0xde69db8, collation=<optimized out>,
 > matchall=matchall(at)entry=1 '\001', fn_extra=0xdeac920) at
 arrayfuncs.c:4116
 > 4116                            if (isnull2)
 Hm.  Just guessing from the location of the crash, but I'll bet I
 overlooked the case of an expanded array with no nulls, ie should be
 -                       bool            isnull2 = nulls2[j];
 +                       bool            isnull2 = nulls2 ? nulls2[j] :
 false;
 I'll commit that in a few minutes, please confirm whether it fixes this
 for you.
                         regards, tom lane
 Fixed the issue.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/3122#comment:3>
