[postgis-tickets] [PostGIS] #3125: ST_LineLocatePoint garden crasher
trac at osgeo.org
Sat May 23 20:41:06 PDT 2015
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: critical | Milestone: PostGIS 2.1.8
Component: postgis | Version: 2.1.x
Keywords: |
This issue looks like it probably got introduced with PostGIS 2.1.7 (since
that exhibits the issue and so does 2.1 and trunk).
SELECT ST_LineLocatePoint(ST_MakeLine('POINT(1 2)'::geometry, 'POINT
EMPTY'::geometry), ST_Point(-11,40));
What is also interesting about this problem, is I can't make a linestring
from the wkt of it:
{{{ -- gives ERROR: geometry requires more points
SELECT 'LINESTRING(1 2)'::geometry;
But am able to using ST_MakeLine or the canonical form
SELECT ST_MakeLine('POINT(1 2)'::geometry, 'POINT EMPTY'::geometry);
SELECT '010200000001000000000000000000F03F0000000000000040'::geometry;
Which I guess is okay since we want people to be able to restore corrupt
data though not necessarily create such a thing.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/3125>
