[postgis-tickets] [PostGIS] #3126: ST_SubDivide garden crasher on Polyhedral Surface
trac at osgeo.org
Mon May 25 16:42:41 PDT 2015
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 2.2.0
Component: postgis | Version: trunk
Resolution: | Keywords:
Description changed by robe:
Old description:
> SELECT ST_SubDivide('POLYHEDRALSURFACE Z (((-72.2 41.755 0,-72.2 41.755
> 1,-72.2 42.755 1,-72.2 42.755 0,-72.2 41.755 0)),((-72.2 41.755 0,-72.2
> 42.755 0,-71.2 42.755 0,-71.2 41.755 0,-72.2 41.755 0)))'::geometry,3);
New description:
Is this even supposed to work with polyhedrasurfaces. If I give a number
like 5, doesn't crash, but gives this error
42.755 0,-71.2 42.755 0,-71.2 41.755 0,-72.2 41.755 0)))'::geometry,5);
-- ERROR: Error performing rectangular clipping:
IllegalArgumentException: Invalid number of points in LinearRing found 3 -
must be 0 or >= 4
So it's trying, whether it should or not is another question
Ticket URL: <http://trac.osgeo.org/postgis/ticket/3126#comment:1>
