[postgis-tickets] [PostGIS] #2034: ST_3DClosestPoint with mixed dimensionality in input values
trac at osgeo.org
Tue May 26 03:11:57 PDT 2015
Reporter: nicklas | Owner: nicklas
Type: enhancement | Status: new
Priority: high | Milestone: PostGIS 2.2.0
Component: postgis | Version: trunk
Resolution: | Keywords:
Comment (by strk):
I noticed ST_3DDistance() is also assuming Z=0 for 2D input, that one
should also be changed, right ?
select st_3ddistance('POINT(0 0)'::geometry, 'POINT(0 0 2)'::geometry); --
2
should instead be 0
Ticket URL: <https://trac.osgeo.org/postgis/ticket/2034#comment:19>
