[postgis-tickets] [PostGIS] #3139: ST_BoundingDiagonal(geom geometry, fitting boolean default false) return linestring geometry (was: ST_BoundingRange(geom geometry, fitting boolean default false) return linestring geometry)
trac at osgeo.org
Thu May 28 09:01:01 PDT 2015
linestring geometry
Reporter: strk | Owner: strk
Type: enhancement | Status: new
Priority: high | Milestone: PostGIS 2.2.0
Component: postgis | Version: trunk
Resolution: | Keywords:
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3139#comment:1>
