[postgis-tickets] [PostGIS] #3140: Temporal Cunit Failure
PostGIS trac at osgeo.org
Thu May 28 09:45:32 PDT 2015
 Reporter:  pramsey   |      Owner:  strk
     Type:  defect    |     Status:  new
 Priority:  critical  |  Milestone:  PostGIS 2.2.0
Component:  postgis   |    Version:  trunk
 Keywords:            |
 Running test 'test_lwgeom_tcpa' in suite 'measures'.
 [cu_measures.c:1089]
  Expected: 3
  Obtained: 3.4
 [cu_measures.c:1090]
  Expected: 1
  Obtained: 0.8
     FAILED - asserts -  37 passed,   2 failed,  39 total.
   1. cu_measures.c:1089  - CU_ASSERT_EQUAL(m,3.0)
   2. cu_measures.c:1090  - CU_ASSERT_EQUAL(dist,1.0)
 OS
 Darwin Crane.local 14.3.0 Darwin Kernel Version 14.3.0: Mon Mar 23
 11:59:05 PDT 2015; root:xnu-2782.20.48~5/RELEASE_X86_64 x86_64
Ticket URL: <http://trac.osgeo.org/postgis/ticket/3140>
