[postgis-tickets] [PostGIS] #3131: KNN geography still gives ERROR: index returned tuples in wrong order
trac at osgeo.org
Thu May 28 13:26:38 PDT 2015
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 2.2.0
Component: postgis | Version: trunk
Resolution: | Keywords:
Comment (by robe):
Try this:
CREATE TABLE knn_recheck_geog_small (
gid integer,
geog geography
INSERT INTO knn_recheck_geog_small VALUES (33768,
'0101000020E61000003D0AD7A370DD57406666666666E62440');
INSERT INTO knn_recheck_geog_small VALUES (33767,
'0101000020E61000003D0AD7A370DD57400000000000002340');
INSERT INTO knn_recheck_geog_small VALUES (33587,
'0101000020E610000066666666669657406666666666E62440');
INSERT INTO knn_recheck_geog_small VALUES (33586,
'0101000020E610000066666666669657400000000000002340');
INSERT INTO knn_recheck_geog_small VALUES (33769,
'0101000020E61000003D0AD7A370DD5740CDCCCCCCCCCC2640');
INSERT INTO knn_recheck_geog_small VALUES (33766,
'0101000020E61000003D0AD7A370DD57409A99999999192140');
INSERT INTO knn_recheck_geog_small VALUES (33588,
'0101000020E61000006666666666965740CDCCCCCCCCCC2640');
INSERT INTO knn_recheck_geog_small VALUES (33585,
'0101000020E610000066666666669657409A99999999192140');
INSERT INTO knn_recheck_geog_small VALUES (33949,
'0101000020E610000014AE47E17A2458406666666666E62440');
INSERT INTO knn_recheck_geog_small VALUES (33948,
'0101000020E610000014AE47E17A2458400000000000002340');
CREATE INDEX idx_knn_recheck_geog_small_gist ON knn_recheck_geog_small
USING gist(geog);
SELECT gid
FROM knn_recheck_geog_small
ORDER BY 'POINT(95 10)'::geography <-> geog LIMIT 1;
Ticket URL: <http://trac.osgeo.org/postgis/ticket/3131#comment:1>
